The ASIC hardware table utilization has exceeded 90 percent for the above resource. This may cause switch performance degradation.
Resources may be freed by unconfiguring certain features, depending on the affected hardware table. Hardware upgrade or network segregation may be needed. Disabling IGMP snooping on VLANs where it is not required, will reduce multicast entries in the L3 table.
Notice
The utilization of %tableName% hardware table on slot %slot% has exceeded 90%%
Name | Type |
tableName | String |
slot | Slot |
